Has this happened to anyone else
You work on a small part sanding cleaning and painting you set it down carefully then proceed to work on the next part. Then after a while of working on the second part you look down at you desk for the first one and poof it’s gone…? I seem to have this affliction
Used to happen to me all the time, but then I bought a pack of those little 2 ounce GladWare containers. When I’m done cleaning a tiny part, I just drop it in that container and close it before moving onto the next tiny part.
Thing is physics work a little differently with smaller objects than with larger objects. One thing to look for is the working surface. For example I like to have a layer or two of paper on my bench to avoid damaging the latter with glue, paint or the likes. Now this layer of paper wrinkles a little after time and can work as a catapult for really small parts. Putting them in a plastic container would surely help. And how about air movements that can move small parts? How about sleeves the part can cling to? You don’t really need magic for explanation here…
Living in Central Florida, I am at one angle of the Bermuda Triangle. When a part disappears, big or small, that’s why.
Heh…and the parts that I do lose? That’s one great reason to have a cat. My cat always seems to find my missing parts…I guess even the tiniest ones are just out of place, and he takes an interest in playing with them. I’ll see him playing with something, wonder what it is, and it’ll be something like a landing light lens that’s been missing for weeks. No way I would have ever found it otherwise.
Happens all the time to me. Gremlins, poltergeists, I have no idea…
I have an apron with large pockets generally when something drops it falls into those. Howeve, at my age I think part of my brain is firing on 6 out of 8 cylinder And forget occasional where I put stuff.
This really is true. The smaller it is, the ratio of mass to surface area is. Mass determines the downward force of gravity. the suface area of small objects determines drag. So small objects fall slowly, and can flip around (falling leaf). It may end up on tme floor far from where you dropped it.
Yeah, that’s exactly what I meant.
A few years ago I had an exhaust pipe in my tweezers.
I had just applied a tiny dot of CA to one end, and as I turned my attention to the engine in my other hand, the exhaust pipe dissapeared into thin air.
It just wasn’t there.
I crawl around looking for it for a few minutes…
Then my eye starts to sting a bit. … the exhaust pipe is glued to my eyebrow !
So no, you are not alone.
Hey fotofrank , Does that angle reach to northwestern Wisconsin? If it does it must be pretty full with all that I have lost over the years.
It still happens to me from time to time, but most of the time I place small parts waiting for installation into a small paint pallette. There are six pots on the pallette so theres lots of room for small parts and it doesn’t take up too much space. Plus, I still can use it as a paint pallette.
I have small tins of throat lozenges that I use. I use one for each model I’m building and the are compact to fit in the box.
Small travel containers of band-aids work too. I keep those around the bench area for some odd reason….
Yes, it happens - in addition to using containers (I use disposable condiment cups, cause they have lids) to contain the parts when they inevitably get bumped. I also sometimes work small parts stuck on masking tape attached to a piece of cardboard. And then sometimes I don’t do either and get some exercise doing dropped part burpies.
Konrad
Yes, this has happened to me. As with others, I have containers that I place my small parts in. I’ve actually graduated up to containers with lids now as I tend to knock things over as well.
face_holding_back_tears
:disappointed_relieved:
My most recent experience was making the instrument panel for my 1/32 BF109E-4. I used Waldron instruments and bezels for this (stashed for more than 20 years!).
Much time was spent on my hands and knees, looking for bezels that flew off the bench. Some I found, but 2 or 3 of them seem to have slipped into an alternate universe.
Glad i had enough spare bezels to complete the job.
This phenomenon might be nearly universal. I am not smart enough to know if it an alternate-universe thing, shape-shifters, or microscopic black holes; but it happens all the time.
We’ve all seen tweezer-launches into oblivion right?
I lost a vertical stab for a 1/48 Fokker D-VII (it is a sorta small part) a few months ago. Packed up the kit and set it aside, nothing else to do. Well, last week I found it sitting on the floor in plain sight. Guess it got launched back to this world by some other poor modeler in his galaxy.
Obviously that made me happy, but I think I said something out loud because a few days later I lost a much larger part. One wing of a 1/48 F-104. Granted that is about as small as any 1/48 wing ever made, but way too big to be eaten by carpet monsters. It fell from my bench, hit my leg, and vaporized inexplicably.
I too have cats, they may be gatekeepers of this phenom.
Among other things… that’s the nature of:
  1. Living with housecats
  2. Being above 40 years of age
