I was wondering how many of you only use your airbrush for the body, frame and tub. And hand paint the rest of it. I have been pulling out my airbrush for small parts. At the moment I don’t have a dedicated bench for modeling. My farther n law passed so he have a bunch of his furniture in the garage yep right up against my bench. So I am thinking on my next build I am going to hand paint the everything except the big stuff.
On occasion when I’ve got a detail color going, like silver for landing gear, or chromate gree, I’ll get a bunch of kits out of the stash and shoot the parts on the trees. If anything, they’ll be primed for the future.
You seem to refer specifically to building and finishing an aircraft model, and my answer is that for me, it depends on the subject, whether I use the airbrush–or rattle-cans–to apply paint or brush by hand. For example, for an aircraft, I’ll apply paint to the large areas–fuselage exterior and interiors, for the most part–by spraying, and paint small pieces and details by hand. For figures, I’ll apply paint almost entirely by hand, though I have started experimenting with spraying, for larger figures (1/6 or 1/8 scale). For a car, I spray almost entirely, for the even application.
But for some sci-fi subjects–Maschinen Krieger–I am experiementing with apply paints to areas, like the exterior of an armored fighting suit, by hand. I thin the paints just as for spraying, and apply layers to build them up. Among the MaK builders I know, it seems to be relatively popular to paint them by hand, especially using lacquers from Japan.
So, it depends on the modeler, and the subject–everyone will have a preference, and for some jobs, one or the other may work better, that is, may be less fuss and produce a better finish.
I often pre-spray everything while the parts are still on the sprues. Wheels, landing gear, tires, interior / cockpit colors, etc. Then, after trimming the parts from the sprues, I trim / sand off any flash left behind on the edges–which can easily be hand-painted to touch them up.
I know guys who mask and airbrush EVERY little black box inside the cockpit…too tedious for my taste. I hand brush the small details.
And yes, I ALWAYS airbrush the outside–occaasionally I will lay down the base color with Tamiya or Testors rattle cans.
For instance: after airbrushing interior green on US WWII aircraft; I will dry-brush a much lighter shade of the same color on all the raised structural details to bring out highlights. It makes the details stand out so much taller once a detail pin wash is applied.
You know , funny you should ask . I usually wait till I have a large number of large jobs , then break out the A.B. Otherwise I just Brush - Paint everything . T.B.
