So, ive been going at trying to reach perfection like a computer without the right code. I see all the results but, im not understanding how to achieve them…doesnt make sense; doesnt compute.
Well, i was watching a you tube series on my current kit, Porsche 918 Spyder, and the guy has same exact car, same brand, Revell, but his must be a different version, because his molding is a different color.
As he’s prepping the body, im noticing not all of his mold lines are matching up, and im getting overwhelmed. I try my best to keep up, but basically skip to scuffing it up for priming, and as I’m doing this, all the molding issues on MY kit start popping out at me, and then, all of the sudden, i get it…its not a 1 size fits all process, but a personal process, as you basically follow the flow of the kit. Let your eyes do the leading…
Another moment hit me yesterday. I was laying gray model masters down as a primer. I understand its not a primer, but i dont have primer, and it’s good practice; helps me find defects.
Anyway, i found a hair after applying my third coat, and i tried getting it out, and before i knew it, i had messed up the paint job on the spoiler, the rear bumper, and trunk.
Up until this point, sanding was more like a tool of destruction for me, ha! Wet sanding was something that just didnt compute either. However, i decided to give it a go. 1st attempt made the next coat even worse…ok fine, 1 more try…
This time, i slowed myself down, and figured if i mess it up, ill live with it. So, the pressure is a bit less now, and i kinda just went with it…just tried to smooth things out as best i could, and the result went great. Not perfect, but theres just a small indent you have to really look for, to see…the rest of the area, looks like it never had an issue in the 1st place.
So, those are my 2 ah-ha moments. I feel like i have gained real knowledge and experience in those areas, and am a bit more confident going further.
Im wondering if any of you guys had any ah-ha moments, where you went from baffled to on the right track? Where you felt a little less lost or overwhelmed?
