The anchor hawsers pass through the hawspipes (which will have to be added to the old Revell kit), then around the windlass barrel, then down the forward hatch. One of the photos should show this reasonably clearly.
Good luck! And don’t hesitate to show the Forum your work!
I recently discovered an interesting Bounty resource.
There was an article in the Chronicle about a Seventh Day Adventist institution called Pacific Union College in Angwin CA in the Napa Valley.
The SDA church considers the missionary effort in The Pitcairn Islands a significant of its history.
At the College there’s a Pitcairn Islands Study Center that has significant documents and artifacts from the history of the mutiny and subsequent settlements.
See , you are darned good at those sailing thingys .Now where were you when I needed a friend to b.s. with , (and maybe help ) with all those thread thingys ? No , really Proff .that’s a nice looking Bounty and thank you for showing her here. You have exonerated this old salt who built one of the wood kits years ago and coppered the Bottom .
Everyone that saw her said " No ! you got it wrong , she didn’t have any coppering !" There was a model of her in the museum of antiquities in Liverpool that did have a copper bottom and that’s where I got the idea . Tis’ true though . She did have the " White ( almost a rich cream color ) Lead " bottom when privately outfitted ,as the private shipowners of the time really couldn’t afford such niceities .
Now , one question .Whe you describe Cap’n Bligh’s face you talk about his upper and lower eyelids . .Good gosh man , did you use a jewelers loupe to build her ? Gees , I thought I was bad .He! He! Just for your information , the wooden kit didn’t have any hawse holes marked or shown either!
@ Jtilley, here is where I got to with the hawsers, I am assuming the recirocal hatches were for crew access to the rope locker and I am assuming the hawsers got there by way of a pipe? Beside the access hatches?
Yes, I know the deck is an awful colour, it was the cream as described in the instructions and I haven’t as yet learned to weather…
Don’t hesitate to post a WIP here, especially if you are new at this. There are tons of people here that would love to help you figure out things along the way. It’s not the results so much as it is the processes. You can save your self a lot of frustration by getting feedback from the experienced builders here.
I can’t seem to understand the problem with the knee of the head that you mentioned. I’m not quite sure what you are referring to do to my ignorance of nautical terms. One guide I found lists it like this:
KNEE OF THE HEAD.
The large flat timber fayed edgeways upon the fore-part of the stem. It is formed by an assemblage of pieces of oak coked or tabled together edgewise, by reason of its breadth, and it projects the length of the head. Its fore-part should form a handsome serpentine line, or inflected curve. The principal pieces are named the main-piece and lacing.
which doesn’t help a whole lot. I’ve examined the bow of your photos and the same on the hull of the kit and can’t figure it out.
Actually that’s a good, accurate description. To make it simpler - the knee of the head is the flat plastic piece that sticks out from the forward end of the hull. (On the kit it’s cast integrally with the hull.) It winds up under the bowsprit, and the figurehead is mounted on the end of it.
To see the mistake that Revell made, you’ll have to have a copy of the plans of the ship. A good way to get them is to get John McKay’s Anatomy of the Ship: The Armed Merchant Vessel Bounty. (I may have garbled the title slightly.) In addition to Mr. McKay’s own superb drawings, it contains photos of the Admiralty draughts.
If you compare the side view (“outboard profile”) of the plans with the Revell kit, you’ll see the difference immediately. There’s supposed to be a subtle S-curve to the forward edge of the knee of the head (that “handsome serpentine line or inflected curve” in the definition above) that Revell just plain botched. I have no idea why that happened.
As I remember, I cut my replacement knee of the head out of either .060" or .040" styrene sheet, and scribed the edges of the various component pieces on it to match the “planks” I’d scribed on the hull halves. (As I said in the first post in this thread, I’m not at all sure that using the plastic hull saved me any significant amount of time.)
Replacing the knee of the head wasn’t a huge job. But if you leave it as is, I don’t think anybody will mind. I certainly won’t.
I saw this in a magazine in the early 80s in a model shop (I guess “Fine Scale Modeler” magazine). I bought the 2 issues but they fell apart over time. I been looking for the issues ever since. Do you know the issues the articles appeared in, so I can search for them?
By the way, I know the size of this Revell kit. It’s small. The detail and workmanship are absolutely spectacular. I also like the fact that you went for realism. Most “plank-on-frame” models are super clean with pristine walnut planks, not like these ships probably looked only five years after being built. Sailing was a dirty and sometimes bloody business. SUPERB JOB!
TrioGio, I’m not quite sure what magazine articles you’re referring to. I’ve never published an article in FSM. (Maybe one of these days…) I wrote a series about the Bounty that was published in the old British monthly Scale Models, in the fall of 1978. As I remember, it was in three parts - but there may have been four. A picture of the model was on the cover of the issue that carried Part I. The printer somehow got the picture out of focus; the editor felt awful about it and ran a short extra article consisting only of color pictures, either three or four issues later. I can’t remember whether that additional article was Part III or Part IV.
Scale Models was a fine publication in those days. It was still being published in the mid-1990s, but for some reason it started really going downhill - especially when it came to subjects other than aircraft and armor. For a while it had the title Scale Models International. I don’t know just when it ceased publication, but it’s gone now. (I guess I should be careful with statements about that. I haven’t seen a copy in the U.S. for years. Maybe it’s still available in England. Or maybe it morphed into another title. The British have quite a few good modeling magazines.)
I have no idea where my copies of those articles are - let alone where to buy them. Sorry.
Thanks, I’ll see if I can find them. The hobby store was in New York around 37th Street in the early 1980s. I didn’t realize they were English. Again – a beautiful model.
By the way, just to prove I had these, I remember you made the furled sails by mixing them with glue, which I thought was an ingenious way to get their detail in scale.
I’m deeply flattered, but I personally wouldn’t spend much of my limited time on the Orb searching for copies of those 35-year-old magazines. Most of the text is covered by the posts in this thread, and the photos in this thread cover just about everything that the B&W ones in the magazines did. And of course I’ll be more than happy to answer any questions.
