hi guys i know this should be in the decal forum but i thought it might get a better responce. i am looking for this product,its called gunze mr. softener for decals of course. thanks rob.[:D][:D]
http://www.greatmodels.com stocks it. I have some and find it to be very similar to Micro-Sol.
thanks swanny
the reason i ask about this is that leading edege suggest you not use mico sol on thier decal. they tend to do something strange to them.[:D][:D]
Try using Micro-set, it’s not as aggressive.
Dear rob,
Gunze has 2 type of Mr Mark. That are softer and setter, setter is a new product which is milky in color, Gunze it can enhance adhesive. I use both. Softer is better and easier to use as setter will have risk in making a layer of fog-like material on decal surace after it dried. They work well on nearly all decals except cartograf!
Its great for tamiya decals -works like a charm ! If possible, test it on a decal from your sheet that you wont be using to make sure it doesn’t ruin them.It shouldn’t be to hard to find…if so, order from one of the many hobby shops on line . Best of luck !!!
