Leetree,
I find alotta this stuff by accident, really. This particular set of images I found because one of them was posted on another forum. Another way to find images is to browse evilbay and see what photos are for sale. Often times they’re tiny images, but now and again you’ll find someone who has large images posted in their auctions.
Anyhoo, you may already know this, but I’ll explain it for whoever may not…
If you see an image posted somewhere, anywhere, you can usually use the image URL to back-track to the directory where the image is stored simply by removing the image name.
Often times, as in this case, the directory itself is not accessible to anyone but the ‘owner’ of said directory and most folks would just give up. But, seeing that the image name was composed of numbers, I set about to find any other images which might be in the directory by replacing the numbers of the image name in the URL.
For example, the URL of the image which I saw posted was:
http://www.bensterer.de/Sven/146.jpg
I then replaced the ‘146’ with ‘001’, which didn’t work, so I then tried ‘01’ and came up with:
http://www.bensterer.de/Sven/01.jpg
Then it was simply a matter of changing the numbers to see each image. Some numbers were skipped, hence the gaps.
If the name of the image is composed entirely of words or letters and no numbers, than this method isn’t worth it unless you have no life and all the time in the world.
But if there’s a number in there somewhere, you can usually run with it pretty easily. Often times there’s not much to be found. However, in this instance, I just lucked out and found a small treasure trove…
Fade to Black…
