Gloss surface for washes
Is it really necessary or can a flat surface be used instead?
Gloss surfaces help pin washes for sure,helps allow it to flow down panel lines and around details.For an overall wash to impart griminess or a dusty look,flat surface works fine for me.
I have put washes over Testors Dullcoat many times and it works fine.
If you try to run a wash along a seam or panel line and it’s a flat surface, the wash will spread out and soak into the surrounding areas. Very similar to putting a drop of liquid on a paper towel, vs a smooth glossy surface.
I suspect that capillary action is drawing the wash into the pits and valleys of the relatively rough flat paint.
This can be helpful if you want to grime it up as Tojo72 mentioned.
On the other had, a gloss surface keeps the wash in the grooves of the panel lines and even if you do get some outside, allows it to be easily wiped off.
For general washes or filters, a matt surface works better.
For pin washes, a glossy surface works better.
