Hey all, I’ve run into a new problem. I’ve started using Tamiya acrylics for airbrushing ( My local hobby store doesn’t have much else). Have any of you had any problems with bubbles in white paint? I’ve thinned and thinned, checked pressure, sacrificed a goat, and still I get an uneven bubbly spray. I’ve only encountered this with whites, no other colors do this.
White can be a bit of a nightmare, as I believe the pigments are heavier, and therefore more likely to clog your AB.
All you can do is thin the paint, and apply a lot of thin coats. It’s boring and frustrating, but it does work.
Best of luck.
Karl
check for a clean brush first… if thats ok drop your psi below 10
Tamiya acrylic seems to need more thinning than MM. I would say a 50/50 mix is what works for me.
Dean
If you can use enamels, Floquil “Reefer White”, A model railroad color, is the absolute best white availble in the model paint lines.
Regards, Rick
I always apply Tamiya fine white or Citadel Skull White primer first (even use it for the final coat as well). This gives a good base for more white airbrushed coats and will cut down the number of coats you will need to apply to get a good white finish.
cheers
[#ditto]
I agree. [:D]
Yep, that reefer white kicks some butt. I’ve used a couple of those Floquil paints though, and they’ve all been very good. I tend to grab them if they’re available in a color that I need or want.
