I am going to be starting the Tamiya German Tiger 1 Early Production Tank. I would like to know if there are any pit falls with this model that I should be aware of when starting. I am going to use it in a 1/35 Diorama as the final build. Any susgestions would be appreciated. Tony/N2GVB -Hamming
it is a great kit. The tracks are one-piece rubberbands, though, so you will want to plan out how to reproduce the sag. I have done it where, I drilled a couple of small holes in the hull and glued cut paperclips pushed thru the hole. Have them stick out so they rest about 2/3 the way across the to run of track. These will hold them down and make the track sag. Just paint them track color and you cannot see it. I did 3 per side. Other than that, the kit goes together with no problems
welcome to the boards, by the way!!
