Is there a Company out there that make a German 88 crew in winter gear?
preferably Russia 1942 Luftwaffa field division? (pretty picky there)
thanks
thanks
Tamiya’s ‘German Flak Crew’, #35094, has 5 figures all wearing a heavy duty 2-piece winter gear over their standard uniform. The painting instructions on the back show either a 2-color scheme or all winter-white. Would that do?
Glenn
you mean a flak version 88, right reb? in that case, then 53ryder’s suggestion for tamiya’s offering is the right one. otherwise, you may have to look round for an AT set.
probably, is it the same crew as in the sdkfz 7 with flakvierling?
don’t know if you’ll read this but here we go. i think you are talking about there greatcoat? if you are no at least not that i’ve seen. but there are some company’s that you will have to mix @ match parts with but good luck!!!
Two boxes of Tamiya ‘German Flak Crew’, #35094 and swap the helmet decals for Luftwaffe ones. You’re going to be doing some surgery, but I think that is as close as you are going to get.
ok, thanks.
