I’ve come across the williams broz GB Z racer kit and I am a little wary about that red pin stripe between the yellow and black paint scheme. I thought about tape but I would rather paint it, any tricks out there? painting a paper thin pinstripe around radaii in 1/32nd scale? wow, I need some advice.
Steve
If you have a scanner, there are a couple options.
Scan the wings, and print them out on heavyweight matt paper. Draw the design on the papaer and cut it out. You can use these as templates for making masks from your preferred material (tape, etc.). For the pinstripes, you can use the above method for painting them, or cutting them from red decal paper.
Hope this helps !
Too Bad CaptBrazil no longer joins us he built that and figured out how to paint it on.
