Gallery Posting
I’m trying to post pictures on the gallery, but when trying the, http://contribute.kalmbach.com. It comes up as an error page.
Hi Pat,
Are you using Windows 8 with IE 11? If yes, please use compatibility mode when viewing the site.
If not, are you getting the error when you first click on the contribute link or after you try to upload your files?
Tim
Hi Tim, I’m on Windows 7. I’m getting the ‘error page’ when I first click on the contribute link.
Hi Pat,
We’ve found that IE11 acts up even if on earlier operating systems. If you use Chrome or Firefox, are you able to get through? If yes, it’s probably the compatibility problem I talked about earlier and can be solved by using compatibility mode in IE11.
This is a direct link to the contribute page.
You can use the link above to test your web browsers.
If the compatibility mode doesn’t clear things up, or you’re getting the error on all Chrome and Firefox, too,it may be a cookie issue. In that case, clearing your cookies would be the next step.
Tim
