Gotta love those finishing touches. It’s this point in a build that seems to take the longest for me. Can’t wait to see pictures Mike. Sounds like its going well.
Thanks, Mustang! I had hoped to put up a picture tonight, but it’ll be tomorrow. Today I did the panel accents on the drop tank, constructed the tank rack, sprayed it and that minor correction on the rudder, panel washed it and clearcoated all, then got the decals onto the tank. At the moment I have a few trim tab markings to go and the three parts of the prop spiral.
My target for tomorrow is decals fully completed and sealed, prop assembled, detail painting and landing gear underway. The burnt metal areas should be the last spray work on the model, to be done after final sealing.
I’ll be glad to have this on finished, it’s been a long job, I started it for RD III, which is a loojng time ago!
Cheers, M/TB379
I use Flory washes all over my aircraft kits now, love the stuff. I have never really noticed any difference in the black from the others.
Bish – it might just be the bottle I’ve got that’s a bit off formula…
Progress today, I finished the decals, including the spiral, blew a few small parts into 76, then sealed everything with clear (with the exception of the spiral, it’s had six coats of setting solution and I’m still not happy with the settle-down, so I’ll leave it till tomorrow, do some touch-ups and seal it then).
Here she is, not a great deal of visible progress:
Also today I did the wash detailing on the landing gear, sealed the tank rack and started work on the tailwheel. Target for tomorrow is to complete the prop and landing gear, and to have her up on her feet. from that point it’s not far to the finish line. I think I have enough pressure in the bottle to do the burnt metal panels too, which I can mask for tomorrow.
Cheers, Mike/TB379
Everything looks good so far Mike. Your paint job looks great and set off by those decals. It’s funny how much difference a few decals can make in the look of a model. [Y]
Really looking great, Mike. This particular shot and lighting really show off your lovely panel line etc finishing. And Joe is right, the decal are really making this one pop big-time.
Looks really good to me Mike, nice work.
Thanks Mustang, Greg and Bush! Yes indeed, I’ve always felt the decals made a model come alive!
Today’s progress hit most of my targets – burnt metal masked and sprayed, spiral finished, touched up and sealed, prop assembled (blades needed touch-ups too), landing gear assembled and touched up, plus I painted canon barrels, unmasked MG barrels and separated and cleaned up the flaps. I had hoped to move into final assembly but a headache slowed me down.
Here’s a view of the underside taken last night, with the masking away:
Note the two different shades of 02 – that Tamiya in the wells, which were painted and weathered early in assembly. The flap bays were resprayed in MM Acryl at a later date, which is a truer representation of the colour.
Next, this is the masking setup for the exhaust panels:
And lastly, the subassemblies ready to be added tomorrow:
Target for tomorrow: mount all these parts plus the antennas and guns, add and paint the formation lights and pitot, do the carbon and dust work, unmask the canopy. Possibly rig a radio antenna in EZ line – at which point she’s done.
Cheers, Mike/TB379
Gettin’ close…REAL close!
Mike, Your big A-8 is looking awesome. I’m anxiously awaiting to see the finished product. Bring it home bro!
Thanks Mustang and Joe! Well, she’s almost done as I type this. All subassemblies from the last photo are now mounted, along with the inner gun barrels and underside antennas. The canopy is unmasked and the flaps are fitted. My next task is to do the dust and carbon work, add the pitot and paint it, and do the formation lights. Some bare metal drybrushing around the heavy wear areas and I’ll be about ready to call it. There’ll be a few small jobs leftover that will be put off for later, explained inn the final post.
Okay, hopefully the next thing you see will be the gallery shots!
M/TB379
Okay, guys, I’m calling her done! As promised, here’s the evidence. There are a few annoying aspects that will have to go on the back burner for some future time, and I’ll have a grumble about them on my blog (last night I posted a review of the Hobby Boss D-9), but in short, they are: flaps set at an unrealistic 90 degrees, separate parts for the formation lights that were useless, a call to be made on what to use for the radio antenna – is EZline too fine to use in this scale? – and doubts about how well the pigments took over the satincoat – they were starting to do the fingerprint powder trick but had not yet developed the kind of streak I’m used to getting at smaller scales. Also, I did not indulge in any significant chipping or worn edges, which I’ll need to research at greater length. One last area concerns the outboard guns, which seem to have been “scabbed on” by Hasegawa, requiring more than a simple opening of a tab slot as I had originally assumed. The parts called for the cutting open of a teardrop shaped opening to fit the base of the canon parts, which would need to have been done well in advance, leaving me with a thorny bit of modification to mount them afterward. This also is in the too hard basket for the moment, and will be on the list to be attended to “later.”
Right, here she is, Hasegawa’s 1:32nd scale Fw 190 A-8, in markings for Hans Dortenmann’s plane, about the time of the invasion of Normandy. It’s been a long time coming and I’m glad to be able to call this one off the bench at last!
M/TB379
Man you’ve nailed as near a perfect build with this plane as I’d say you can Mike! I hear you on the 90 degree flap angle and don’t know why some kit manufactures do that. The paint and weathering blow me away here as it’s all well executed. With the antenna, use the sprue method. I was really bad at it too and forced myself to sit in front of a candle with piece after piece of straight sprue cut up beside it (dude I’m talking around 20-25 pieces here) and started stretching until I could succeed in making the same thin strand 5 times. It really pays to learn this trick.
Let me know which pic you want to use for the intro pic and I’ll get er pinned up! Thank you Mike for your participation here and looking forward to building with you again in the near future.
Mustang – thanks so much for the appreciation, it’s high praise indeed! I’ll have a crack at stretching some sprue and see what I can achieve, I certainly have plenty to go at given the amount that ends up binned when empty parts trees go out!
For the pic, how about the first one up above?
I have plans for anywhere up to six Bf 109s for the GB next year – a D, 3 x E-4s, an F-2, G-2 and G-6… I might be over-ambitious there, but I guess we’ll see!
Lots to do, the A-8 makes seven completions for me in this calendar year, and I have nine more on my roster for 2014, of which six are close to the painting stage at this time.
I look forward to seeing how Clemens brings in his schwarm of Butcherbirds – and speaking of whom, many thanks once again for the help on decals!
Cheers, Mike/TB379
Beauti of a build sir!
Mike, What a marvelous piece of modeling you have produced. Really, really excellently done. Despite your misgivings with some aspects of the model you have built an FW 190 that appears every bit the look and feel of a Bad A Butcher Bird. Thank You very much for sharing your skills and talents with us all. It has been a real pleasure.
Hey Mike great work. Nice to see you finish here. Any way to modify the flap angle? And did you say there were no outboard 20mm on Dortemanns’ bird?
Thanks Handiabled, Joe and Nathan – I blush discretely! It’s been a great pleasure to take part and I’ve picked up knowledge and skills along the way from the great talents sharing this GB!
Nathan, the flaps are an interesting point. At the moment they are just press-fitted, so I can unhitch them at will. I could either try changing the angle of the tabs by scoring and bending, perhaps with the plastic softened with liquid cement, or I could remove the tabs altogether and glue directly, though it does not look like there is a common edge to work with. Re the outboard canons, Dortenmann’s plane certainly had them, it’s the kit engineering that took me unawares and I’ll need to very carefully rejig things to attach them directly to the wing out surface. That really is a “superglue and prayer” situation and they’ll be very delicate. That’s for a later time, though!
Thanks again Mustang and all, it’s been a great build to be part of and I’m glad to have added three subjects for my Fw 190 collection in one hit.
Cheers, Mike/TB379
Oh, and just to show that enthusiasm never flags, these arrived in the post recently:
Other than the bagged Tamiya F-8, they are all of Trimaster lineage. I’m hoping to get to a couple of them in next year’s build roster.
Oh, and there were of course an equal or greater number of Bf 109s in the post in the same period, too!
Cheers, M/TB379
Mike, you truly did a beautiful job on that bird. Everything is just spot on. Truly like the subtle weathering/finishing. That bomb really pops, btw. Adds a lot and I love it.
This one was particularly interesting to watch come together. It all came together so fast that even with my feeble memory I still recall what she looked like a few weeks back.
