Future
I am diving into the “future” trend and am using it for the first time. My first attempt ended in failure. What color Aztec tip works best with Future. I tried to hand brush it on and had good results where I was able to keep it relatively thin, but this stuff really needs to be airbrushed on. Any pointers??
Hmmmm I don’t have your air brush, but I think I understand the program. I use a paasche single action and shoot a fairly heavy coat. I shoot it on straight. No thinning at all. What exactly happened when you sprayed it on?
best way to spray on the future is to use the lowest setting on your airbrush and just spray it on…it is pretty forgiving stuff, you just have to find that fine line between too heavy, and orange peel…it spreads itself out pretty well, and as long as you dont over do it, it comes out ok…(if you want to remove it, best thing to do is dip it in rubbing alcohol - works like a champ, and lets you try try again) Good luck
