Future Floor Polish?
Hello all,
I have been advised many times to use Future floor polish to finish and gloss my models. As a beginner, however, I do not use any type of airbrushing and rely on spray cans. Can someone please advise on how to apply the future floor polish to my aircraft, other than brushing it on that may leave an unsmooth/streaky finish. For example, is there some sort of Aerosol can I can buy to put the Future polish in to actually spray it on my model. Also, I already have one coat of the Testors Gloss Coat on my model, would that prohibit me from using the Future to finish off my model. Any suggestions would be most appreciative
Again, thanks to all. The advice & responses I receive is always terrific and is making me a better modeler.
Paul
Hi Paul,
Lucky you, Future can be applied with a brush and won’t even leave brush marks… I’ve never seen Future re-acting with anything so far… You can always try it first, but I’d think you’re safe there!
I prefer to airbrush Future, but I do use manual brushing on small parts like canopies. Hand brushing a large area might in fact produce the lumpy, uneven finish you fear - it might work with a flat, broad brush. Experiment on the INSIDE of a fuselage. Good luck!
quote:
[/quote]
What do you use for thinner and what ratio?
x_ryu_x Future needs no thinner, the only things you want to add to Future is Tamiya Flat base to lower the gloss i.e Semi-Gloss or a colour for maybe tinting the F-16 cockpit.
Hope this helps
I always hand brush future. I use a soft flat 1/2" brush (made by Humbrol). Decant the future into a film canister, which is secured to a base, with double sided tape, (anything will do, just to stop you knocking it over). Dip the brush into the future, the important bit is to scrape most of the future off, on the edge of the film canister, now you see why it needs securing to a base. The amount on the brush will cover about 1/2-2/3 of the wing of a 1/48 scale P47. Future (Klear in the UK) is self levelling, all you have to do to achieve a flawless finish is to take your time. be carefull at edges and detail, the Future will tend to pool but just soak it up with the brush, like blotting paper. If you have just loaded the brush with Future, then dry it off a bit first (so theres room to soak up the pooled stuff), on a paper towel.
Take a look here at my Tamiya Dewoitine D.520, it was hand painted with Future, here:
http://groups.msn.com/_Secure/0SQD8Av8U*PIEdKoIWUH7zz4IfdbhS5KSpgVs475BZnIlGKw7pWWjLeDyH7rr5Q!htjO1GuKMQ9NFt0hprGnHfp829s0s2!!MScIUcezVncUrWPnhaX*5yg/Dewo-250-a.jpg?dc=4675404503865895347
Mal[8D]
PS I have found that to air brush Future you need high pressure[?]
I had a lot of trouble getting a good finish while airbrushing future until someone told me about using high pressure. I now use 40psi and it works great.
Paccardi, you should get yourself an airbrush. I have used most of testors brand airbrushes and they are pretty good. plus they are inexpensive. the bottled air cans get pretty expensive but airbrush compressors really aren’t that expensive (less than $100). it doesn’t take that much time to learn to use them pretty well.
