What is the best way to thon Future Floor Polish?
Always seems to go on too thick
Thanks
Thanks
If its going on to thick you might want to get a new bottle. I’ve never had a problen with it being to thick, I’ve even airbrushed it straight from the bottle, no problems.
A few drops of Windex, or rubbing alcohol. I too have found it doesn’t need much thinning at all.
Okay !
Now here’s a good one for you . I applied Future to a new clean paint job and it ( the Future ) fisheyed .What made it do that ? Remember new paint ,dust free and the same brand I’ve always used .
That is weird! Did you rub down the model prior to spraying the Future? If you did you may have contaminated the surface with something oily that you weren’t aware of. If there was any moisture in the airline the water will cause fisheyes too. I brush mine on and it goes on smooth as glass.
Grease, oil, fingerprints will make it fisheye.
