I air brushed Future onto my Paladin prior to putting on the decals. That worked fine. My question is what is the best way to clean the AB after running Future though it? I flushed the AB out with Windex followed by some alcohol and went to use the AB a week later and it was a gummy mess. I normally use Tamiya Acrylic paint and clean up with rubbing alcohol and this has always worked fine.
This is just a wild guess; You may have missed a bit of Future in you original flushings or there was a small bit of a prior paint still in the brush and the Windex-Alcohol caused the resultant “sludge”. But your clean out method should have been OK.
Maybe a another flush through or two, next time, before shutting down.
You are probably right. The last couple of times I painted I didn’t disassemble the AB, I just flushed it out. There was probably some residual paint left. My own fault for tying to take a short cut. I will do a thorough cleaning before and after the next time is shoot some future.
I typically clean up my brush with Windex and alcohol as well. I will also, at times, place my finger over the end of the brush and “back-flow” air into the cup and then continue flushing. Doing this has never caused any problems for me.
Some acrylics such as Testor’s Acryls actually do not thin with alcohol. They use a proprietary thinner and alcohol will just make it a hard and impossible mess.
I have a airbrush just for future painting …after i flush with windex and water …i take apart the gun into its parts and pop them in a cup of alcohol over night just to make sure all the guk is dissalved
