i have a priest -kannagroo that i am working on and am about to paint it. i was looking a the top of the hull and thier are serveal fuel caps so what the best way to make fuel stain runs or spills on the hull thanks rob.
I like to use tinted thinner. Diesel and Gasoline have a brownish tinge. Apply it in a manner with a small brush around the filler cap to simulate spillage. Then brush it towards hull sides and down the side as gravity would do with it over time. Refuelling is often done in the dark when crews are tired and can not see well.
Careful not to overdo. I place a dots of raw umber, white and Yellow orche then bush with turpinoid to get it to spread and run down the side a little. It is not one color but the shades of all three with the edges blended. Try it on some spare plastic first because it is easy to overdo.
Tamiya has an enamel paint they call ‘smoke’. I mix in a small amount of gloss black and sort of apply it like a small amount of wash around the caps. It looks well because it’s glossy gives an oily look to it.
You can do it with thinned, and I do mean thinned black gloss (ratio 90:10). Apply as needed, then add as needed.
Do this with oil paint since they are slow drying. Give you plenty of time to observe then make correction as needed.
Ben
GA. modelmaker: Here is a description of the technique I used for my T34:
The fresh oil technique: I used raw umber oil 30% mixed with mineral spirits 70% and then 3-4 drops of gloss varnish. Dab SMALL amounts on flat surfaces in logical spots. As the mix thickens (say overnight) re-dab previous areas with even smaller dabs more in the middle. Keep letting the mix thicken and repeat/dry/repeat until, when dry, the “oil” has a slight sheen. You may need to add a drop or two more of the varnish as you go. The consistency of the mix works best when it has the same consistency as real motor oil. The oils on the vertical surfaces are done the same, just start the first application with the mix after it has sat overnight. It’s O.K. to be generous in some areas where the oil would naturally build-up. Keep dabbing in the same spot and let the “oil” run naturally where it will.
Call it fuel, call it oil, it’s a matter of the amount of coats added to build up the look you want. Here’s the final product:
Hope that helps!!![tup]
fuel stain on my T-34/85— done with future floor wax— right out of the bottle with a little brush----tread[8D]
I have used 3 in 1 oil for oil and fuel stains before ( plus you get that scale machine smell,LOL) and had pretty good results from it.
You have to thin it some, I would say 30%.
Hummm, I think I like the future floor wax look though.
I have this great pastel set that has almost every type of weathering.
It cost 40$ CAN but has everything from dirt to rust (light-med-heav) and the results are super like this.
One color is called, “smokie grey” I use it when something mechanicla (like a engine or underside of a truck) get use, its also good for fuel stains.
(I wonder what old blues, old yeller and green could be use for?)
for my KV I, I used tamiya smoke color and oil paint…
for my JS-2 I used oil paint only
Another thing to remember is that if it is diesel and used in a dusty area, it will turn into a dirt blob. If fuel is leaking out then a wet looking dirt. If just sloshed over during filling then a dry dirt spot.
Here’s a shot of my HEMMT with fuel stains on the tank. Done with built-up layers of Future tinted with a leather brown.
If you experiment with oil paints you can get very realistic results.
Dave
