From the only "Unofficial" GB going.......
My almost completed Tamiya Pershing. I went for a late-war look on a Zebra Mission tank, no infantry phone, no reinforcements on the final drive housings, and the tow cable will be in a ready-to-use position. I’ll probably use the fair-to-middlin’ kit figs. Still to be done: turret stowage, dust, tow cable and the base.Tracks are Friul, the rest is pretty much OOB.
The actual unofficial thread in the GB forum has some nice work, it’s worth taking a look at.
Cool! I like the look with the fenders knocked-down!
Definitely has that mean/heavy look to it. [Y]
Thanks, guys. I wanted the look of a Zebra Mission tank that has seen some service. I plan to pose it on a RR grade crossing, slightly hull-down.
Very nice,I like the shade of OD that you achieved.
I’ve read so many times that Fruils just don’t work well with US tanks but yours look just fine to me.[Y]
All looks GREAT
Tony Lee[:)]
And thanks again… :slight_smile:
Anthony, it’s MM OD, over dark green, over Krylon gray primer. There’s a very light acrylic black wash, heavily thinned with rubbing alcohol, on top. It still needs dirt/dust, and then clear flat.
Tony, I do them a tad loose when they’re unpainted, and the painting process “tightens” them up a tad. Some times it works,sometimes not, but this one came out right. The Magach I’m also doing at this time came out a tad tighter than I wanted, a little visible sag would have been fine on it. Other than that, I’m a one-piece guy. All my VVSS Shermans get DS tracks now, super easy and well detailed.
