Fourm Problem's
I dont know if anybody else has had this problem but every once in a while i can’t get in the forums I did a print screen of the message i get see below. Is this an internal issue or is it external and can this issue be fixed?
It’s definitely an internal issue.
OK thanks Dave
I have this same problem occasoinally. Its generally when I try to post and hitting the refresh button never seems to fix it? I usually end up having to go to the Forums main menu, then access the thread again.
I am also having the same problem. It is when I try to enter the forum site. I just X it out and try again, which sometimes works. At times I have to do it three or four times before I can gain access to the forum. I do not have this problem with any other site.
