For Quagmyer AIRCRAFT OF THE DAY ( XP-67 Moonbat)
well almost since the start of the Aircraft of the Week you have voted for the XP-67 Moonbat so here you go.
McDonnell XP-67
The XP-67 project started out as an unconventional design submitted under the 1939 Army Air Corps Proposal R-40C which resulted in the XP-54, XP-55 and XP-56 designs also.
After two re-designs ordered by the AAF, McDonnell was awarded a construction contract for two aircraft on 22 May 1941. The first aircraft (S/N 42-11677) was completed in December 1943 and featured a sleek aerodynamic profile. The exhaust gases from the turbo-supercharged Continental engines were used as a jet-assist to increase performance; however, the rated horsepower of the “Hyper” engines was not achieved and the aircraft fell short of performance estimates.
The aircraft was destroyed in a fire on 6 September 1944 and the project was canceled before the second aircraft was built.
TYPE
XP-67
SPECIFICATIONS
Span: 55 ft. 0 in.
Length: 42 ft. 0 in.
Height: 14 ft. 9 in.
Weight: 17,745 lbs. empty/23,910 lbs. gross
Armament: None; designed for four 37mm cannon
Engines: Two turbo-supercharged Continental XI-1430-17/19s of 1,350 rated hp. each (approximately 1,050 hp. actual)
Crew: One
PERFORMANCE
Maximum speed: 405 mph.
Cruising speed: 210 mph.
Range: 2,000 miles
Service ceiling: 37,000 ft.
XP-67 Photo Gallery
http://www.wpafb.af.mil/museum/research/p67-1.jpg - (Larger version of above photo)
http://www.wpafb.af.mil/museum/research/p67-2.jpg
http://www.wpafb.af.mil/museum/research/p67-3.jpg XP-67 in flight
Model Aircraft Reviews (XP-67 Moonbat)
Rareplanes 1/72 Vacuform http://modelingmadness.com/scotts/allies/us/p67.htm
Mac Dee did make some beautifully sleek aircraft in their day.
Darwin, O.F. [alien]
VA,
There is an article in AIr Power that is the only place I found a picture (albiet not great) of the cockpit.
There is also a 1/48th scale moonbat by collect-aire.
It was a beautiful aircraft. Too bad it didn’t survive as a museum piece.
Regards, Rick
That’s a gorgeous aircraft. Looks powerful to!
