FOR ANY ONE THAT INTENDS TO BUILD THE HAMPDEN…
hi all,
since we last talked about this poo this is what i’ve done and its doing my head in !, there are no parts which fit nice, i’m begining to think that these frenchies have never built it up
when you try and scrape the plastic it flakes up ! or make a line in the plastic it lifts up .
well here goes…
wheel wells made up, nothing fits very poor,trimming/trying parts all the time for fit, took one hour to make these up
the resin engines have a resin mounting piece which should have fitted into the grey piece, but didn’t so i had to trim down the resin on the back of the engine mounting
when i built the engine nacelles up i found out that the resin engines would NOT go in when i tried to put them in so i had to trim the tops off the engines to fit in, the nacelles are thick/thin inside and looks like mashed potatoes LOL
the inside does not fit either,there is a box section which looks like the spar, this has to be trimmed down it is too wide to fit the sides on.
not glued in yet,there are no points to where and fit this part all all
i think there are some fit problems, just look at the quality of the moulding
no wonder the french eats frogs legs.
i’m speechless the wheel doors are made up of two parts - outer skin and the frame work, guess what straight frame, curved skin did it fit, i even had to trim bits away from the wing hinges so the frame would fit on !
the rear wings are made up of two parts to each piece and are too thick and don’t align up with the fuselage.
lets look on the bright side the props look ok, but if you want to make the model with out the spinners on there is no cover ! so you would have to make your own.
