foil -how to ????
Actually I’m not some big plane builder but I’m so intheresting how do you people apply alu foil on your models for nmf ?
whitch glue do you use ??
TNX
Dragan we don’t use Alu foil (or at least i don’t)we use Bare metal Foil which comes in a range of different BM finishes and is self adhesive, the foil itself is quite fragile and you have to be carefull applying it but if you get it on right it looks great, the biggest problem i have encountered with it is dust, it shows up worse on BMF than on any other finish…
I have used Alu-foil as Bare-Metal foil is impossible to obtain here. Applying modge podge, and adhesive used for decoupage, with a sponge, then placing teh foil and burnishing it wit an ear bud has worked for me.
Hello Dragan,
I hope this can be useful to you (thank you Amcfayden for the link [;)])
http://www.finescale.com/fsm/objects/pdf/foiledlightning.pdf
Tnx to everybody Now is everything much clearly to me !!![tup]
