my canopy has been dipped in future. but i accidentally sprayed clear flat on it. now it is fogged up. is there any way to fix this.
Try using some ammonia cleaner solution, which should remove the Future and the flat. If the plastic has been fogged, some polishing and another Future dip should solve the problem.
Rick
try stripping it with windex. it might cut the future and since the flat is over the future, it might take it off too.
worth a shot.
thanks guys. it worked great!
blast! 11 seconds!
glad it worked out tho
