! Hello, I’m starting this thread because I was inspired by one created by Ian from Mansfield, England. He took us through a step by step build to show us his progress and pain with this kit and motivated me to get mine off the shelf and onto the workbench. I only hope mine turns out half as good as his did. I am really just getting started and will try not to duplicate his comments. I have and am experiencing all the same issues thus far with clean up and fit. Ian’s photos and warnings have been indespensible thus far. Thanks Ian[:)]
So far I have roughly finished the cockpit. During my sanity breaks I have searched the web for any pictures I can grab for references and info. There is quite a lot available for the Halifax bomber so I take a lot of breaks.[:-^]
I added a few things to the cockpit like photo etched red and green levers and guards on the rear wall, a padded mat for the bomb aimer and a dial for the compass that I thought was a lavatory for the pilot.[#oops] One thing different that I am doing is adding a crew at the request of my youngest son. This required extensive reworking of the compartments. Very challenging and honing my skill with the scale ruler. After much effort I have successfully created figures that fit properly every where but the radio mans area directly beneath the pilot. ( That dude has to be 4 ft tall or less to have fit in there.[banghead]
The figures are self cast in Aluminite. They are a mix of many figures and carved positions to get the pose I want and the fit in the compartments. I was going to use a Tamiya Landcaster crew but they looked like giants and would have never fit. The pic is kind of poor but I’m still learning how to take pictures.[%-)]
Here is a great example on how following Ian’s thread saved me some work. The wheels will not fit once the halves are glued. Thanks to the heads up I was able to avoid major surgery. At least on the landing gear. They still are tricky and tight to fit but they will fit. Some liquid cement and pressure closed the seam well and cleaned up well once dry with an emory board.
For a break from the mundane work of clean up, I did some work on the resin Hercules engines which are a bit soft on detail. Looking at pictures of the real thing I was shocked at all the plumbing on them. I got out the pin vise and drilled out the piston exhaust and made some pipes from wire. I stopped there because not much more can be seen once in the cowlings. That is about where I left off. I plan on finishing the painting on the crew and hopefully joing the fuselage together before I get back to work. One good thing about this kit is my job seems like a break after tackling this bomber. Thanks for looking. Whoopie!
Well done Aaron! You are a braver man than I to build this kit. I thoroughly enjoyed Ian’s article as well, but was not ready to build one of my own! I look forward to your WIP reports. [tup]
so far so good Aaron [;)] i’m glad i got you to get your halifax out, just too many have brought theres…looked into the box and thought what a load of crap, then seal it up for ever [:(!]
you can get alot of info from halibagphil’s halifax build…
That link is amazing. Looks like when he gets done it will really fly. I was am in the process of adding a hand rail and chutes on the left wall but his detail is awesome. Thanks so much.[#toast]
Ok been busy with work guys. Have to earn money for the electricity that the dremel tool is burning up. I met my goal getting the crew finished and the fuselage halfs together.
All crewed up. Painted them the colors as described in the Tamiya Lancaster directions.
The clear parts are just blah! Translucent at best so at least for the side windows, I dug in the garbage and found an old plastic wrapper or case from the box of a toy or electronic item. Not a perfect solution but at least it made clear sturdy windows and could be trimmed to shape with scissors.[:)] I included a picture to show how nice and clear this piece of garbage was.
Now came the fun part, I test fitted this fuselage many hundreds of times to try to make the joining of the halfs as painless as possible. I can compare it to having a tooth ache while spilling hot coffee in your lap.[censored] The pieces are not exactly enginneered for ease of assembly. So I started from the front and super glued and accelerated my way to the tail. I usually like to use liquid cement to mush the plastic and hide the seams but the tension and pressure needed to keep this thing lined up and straight made that not an option. The plastic is also really to thin and soft for clamps so I jumped in and made the best of it.
Now to deal with the seams I am using something new for me. This stuff called Mr Surfacer. I have heard so much about it I figured this was the model to see if it stands up to it’s reputation. So far so good. My idea was to try each of the different grains and spray can but my order was hijacked. Someone opened the box and took all the Mr Surfacer I had ordered. ( Hope they don’t try to use it as an inhalent as this laquer based stuff is pretty stout, The fan is in the window for a reason.)
Not the best pic but you can see how it hides the seam well. Along with my mess on the desk. I sure have a lot of stuff I’m using to get this thing together. ( Don’t try this at home)[xx(]
Know what this is a picture of? No not that! It is the view with the lens stuck in the rear turrent opening looking forward. I really need to learn how to take pictures.[}:)]
Alright had a little more time and tacked the wings. Surprise they don’t fit together either. Also if you look at the pic you can see that some of it isn’t there by the flaps. That’s not from sanding it was molded that way. After many more kilowatt hours of dremel tooling and some filling of the mold inperfections the look ok and dry fit pretty well on the fuselage.
What’s next? Oh boy can’t wait. Ian has warned me about the vacuform parts. I’m going to have to meditate on those for a bit. I’ll probably focus on the engines and wing stuff. Wish me luck and thanks for looking![^]
Ok week 3. Been doing a little bit day by day. The progress has been very slow. Having to clean up flash , thin parts and test fit is not very exciting but is very time consuming. My son who wanted the crew was also very concerned that the propellers would not spin. So throwing caution to the wind, I drilled out the resin engines. Not an easy task I think I had one smoking so much it nearly caught fire. After boring through I inserted the same diameter plastic tube and used a finishing nail for the shaft. Pretty crude but it works.
The resin engines are rough but the detail added looks nice when looking at the real thing. The close up kinda scared me.
I fought with the dome thingie on the bottom primed the whole thing with red oxide primer and sang the Rolling Stone’s song Paint it Black Then I tackled the wings and gear and such. After many trials in the test fitting of parts. ( not a thing goes together easy on this) I actually got the nacilles and wheel wells to fit nicely by enlarging the size of the rectangular hole in the wing bottoms almost to the edge of the scribed line showing the placement location of the parts. There are some extra plastic nubs on the bottom of the wheel bay. ( none detailed side) I almost chopped them off but noticed that they were perfect to hold the completed bays to inside of the wing top. Is this by design or just a happy accidentt? Who knows? The Gear assembly was pretty easy. Using the advice and notes from Ian it was pretty painless. They actually fit so well I glued them together before painting just because. Still toiling with it. I am enjoying it so much I may order at least 3 or 4 more FM kits. Thanks for looking !
looking good Aaron, you should make yourself some kind of ‘jig’ to hold the fuselage level when you put the wings on, also make sure the spars fit well and hold the wings firmly with out glue, if there not the BIG wings will flex on the fuselage and they will look like a real bird trying to fly [:-^]
Still at it. Bit by bit, little by little it is coming together. Have the wings complete except for the exhaust and painting. You can see by the pictures of the resin intakes that they are going to be perfect fits and some even have their own flak damage detail included! Egads![tdn] I am purposely using a fast drying laquer red oxide primer. As much as I washed and sanded the fuselage there was still places that the paint wanted to bead up. I’m not sure why something with the softer plastic I recken. The laquer primer actually bites into it and since it is fast drying (less than 5 min) it doesn’t char the surface of the plastic. Best to test it out on an inside spot that doesn’t show 1st just in case.
Ok taking a deep breath, I ventured onward.
ian lanc wrote the following post at 05-11-2008 6:12 AM:
ian.
I always look forward to good advice. We had a saying in the Army about advice only being good when used. My wood working skills lacking I did the next best thing. During WW II with the bomber crews facing death daily they became understandibly superstitious. Good luck charms and rumors of aircraft gremlins abounded. Well this kit is definately full of gremlins. So I ask one for help. He said I must unlearn what I have learned. Only then when I become one with the model will the pieces fall into place. Then something about the force being with me but not to force the spars because the forward one is too long and hits the wheel well. [alien]
All funning aside I did some precision measuring and cutting and the wings fit tightly with no glue. There is hardly any gap between them and the fuselage and they look pretty dog gone straight. How did I do that? Thanks Ian!
Other advice that I am using is my resin replacement guns arrived today. Ian’s just looked so much better that I couldn’t justify not adding them. Especially with all the work in this thing. Sending the wife out to go find me some future, so now I have no excuse to put off working with the vacuform parts. Should be a wonderful experience.
Well here I go again, my wife did a great job of getting me a new bottle of future. The name hs changed to Pledge with Future shine. Same good stuff though. Good thing this stuff last a while cuz she had me pay her back the $8 spent on it. Thought she would be willing to donate to the cause? Guess not. [8-]
Well kids are in school and she is at work so I have no excuse but to tackle the vacuform parts I have been dreading. I have already double dipped them in future, let them dry for a day and dipped them one more time and let then dry for another couple days. So here are my tools and set the timer please…[:o)]
First off ,time to make a fresh pot of coffee! I learned when I coached rifle teams in the Army that a good cup of coffee really steadys the hand. ( Try it out it really works for me) Next you can see the future did a pretty swell job doing what it does. Grab the silly putty and warm it up a bit with your hands. This stuff is indespensible and I’ll explain why as we go along. Pick your part and mush the silly putty inside of it.
This stuff is great. Firm enough to add just the right strength to the flimsiest of pieces and leaves no residue whatsoever. nowto get brutal. I have one new sharp knife and a used duller one. I score around the piece just like any other vacuform part with the sharp knife then actually cut through it into the putty. Of it is a tricky turn or curve I use the duller knife as to prevent a sudden uncontrolled cut.
Ok another great benifit is you can use the putty to anchor the piece for a good hold and I push my finger into it to give an extra valuable buffer between my fingers and the blade.
Ok first parts out. Here is where the putty does another job. Leaving it inside the part grab your sanding stick and smooth out your cuts. The putty will not sand and will not gum up your sanding stick. Have at it as it works so well it is easier to shape using this method than to trim and trim. The sanding stick simply pushes away the putty while shaping the part. Worked great and I sanded them just like a normal plastic part with lots of vigor and no problems.
Ok coffee must be kicking in as I am getting into a groove. My cuts are getting so straight I hardly need to clean up the parts. This is working better than I had hoped. [swg] There is no static from the putty and it keeps all the nasty sanding dust off the parts along with finger print oils from my fingers.
Well are the parts are free and cleaned. Time taken 1 hour 35 minutes and that is taking time out to make coffee and feed the dog. Actually took more time to put up these pics but it was much easier than I thought it was gonna be. The tail turrent was a little tricky and flimsy. I don’t know how you could do it with out a method like this. It was a real time saver for me. [8D]
Oh before I forget I have been playing around with the top turret. I actually drilled through the whole assembly and using one of my wifes straight pins made it to where the guns will pivot and elevate. The tail turret is all resin and while it could be done I am not sure it is worth the time needed to accomplish this. I have so many more models yet to build. Really I do. Egads![]
Doing some tediously slow work. Masking, researching nose art, extc. Will have more pics up soon. I did want to put this valueable tip out to all who may read this… It is not a good idea to paint satin black outside in the dark. Nuff said.[xx(]
[#wstupid] hey Aaron don’t forget that theres an escape hatch near the navigators part you’ll have to scribe this square underneath the fuselage and don’t forget about scribing the lines in on top of the fuselage where you’ve fillered [:D]
Wow things have slowed down. Mostly because my assembly sequence is from outter space. [alien] Ian, I completely missed that escape hatch. I checked your pics as a ref so it will be there. I put my new scribing tool in the pic. Went right out and got it after reading your post.[:I] I was er just about to get to that step. Yeah that,s it.
The paint job is to let me check for imperfections that have been hidden by the primer. Found a few more than I thought but got em fixed, especially around the engine intakes on top of the wing.
Wow this thing got large. I am glad I have waited to glue on the wings just to make it a little easier to handle. I also dry fitted the window parts and checked the fit. Not too shabby and even easier if I don’t have my ceiling fan on high. [C):-)] Hey it’s hot here in Texas.
I may be getting a little carried away but things you may notice are how the demarkation line on this particular aircraft is a little lower. Another reason for the pre painted look. Besides that red primer was ugly. I’m saving the good tape for the final shot. I tend to mask and remask a few times until I get what I want so I use the cheap stuff to start. I think the windows came out pretty swell. Not perfect but clearer than I expected. Makes me almost want to tear it apart and start over super detailing the insides… ALMOST [(-D]
The painting and drying part slows the momentum down but makes things stand out better in my mind so I try to be patient. I really thought this kit was overpriced for what it was but it has made me feel 10 years old again. Especially when I put a big yellow thumb print on it by accident.
I only have these two kinda fuzzy photos of the aircraft that I am shooting for. Probably easier aircraft to use but why be easy now? If you have any clues on the colors especially around the engine cowling.(looks almost black to me) Please scream it out. Or if you know more about this 462nd aircraft please holler at me. That goes double for any suggestions in the build as well. I’m pretty thick skinned. Thanks for looking!
Aaron the exhaust collector fairings i mixed a sort of colour that looks like burn’t copper, i used matt black/matt copper and a very dark brown, i kept mixing them until i got a colour i was happy with.
heres a picture of the sort of colour you want maybe even a bit darker, they went very dark when they were a veteran bomber, the restored halifax at canada are painted
black and white pictures give you a false sence of direction !
only paint them a copper colour only if your model depicts a new one just off the production line !
COME ON YOU GUYS GIVE THIS LAD SOME MORE ENCOURAGEMENT [;)] he doesn’t seem to be getting much [:-^]
Yeah sorry Aaron. I dont know how i missed this thread. Your doing Stirling work fella. I dont know how you were brave enought to start another after Ians Great build. But you did and it looks fab so far fella. Keep it up. I cant wait for the next installment.
Well one thing about this model is that it is very unforgiving of shortcuts. I had this great idea to mask the window parts with bare metal foil by cutting out a nice smooth piece and painting it black.
Now this idea still has promise with a lot more patience. Of course I peeled of the one big piece and covered the whole tail turret ith it. Big Mistake! The foil is way too thin to control and krinkled to the pointof making the part looked like it was wrapped in black plastic wrap. So what I thought if I have to redo it I might as well practice around a few windows to see how it works. Bug Mistake # 2. I picked the hardest part to experiment with and after some so so results trimming and such with a new sharp knife realized that I had actually cut out a window.[yuck] Well there are quite a few ways and techniques used to get those nice crsp window lines and apparently I suck at all of them. Not to be beaten I tried something else new on the spare tail turret. Its called EZ liquid mask. Don’t know where it came from but have had it for years. So using a spotter brush painted all the clear areas and finished by adding a little dot to make it thicker in the center to ease removal. Letting it dry and will let you know how it works out. You can see the other turret. Another thing I realized too late was it makes a nice aluminium colored inside. Real pretty unless it is supposed to be black…[#wstupid] Oh well wasted a lot of time learning how not to mask clear parts.
Leaving things on a positive note I added some gunners to the turrets with the new resin guns. Not to shabby and look cool behind the windows. There is not a lot of detail in the top turret so having this fellows blue eyes looking back at you helps out.
Probably just going to finish up the tail stripes and take a break. Gotta go back to work. After butchering the tail turret probably need a little breather to get my mind right again. Thanks to all for the comments and support. Feel free to give advice or suggestions. What I’ve gotten thus far has been truely useful. [X-)]
Ok last pic of the night before I’m off to the choo choo’s. The liquid mask works. Looks good but not great. Some of the issue may be in that the part windows are not exactly crisp. It is also so flimsy it was tricky to get the mask off especially using only the none cutting side of my knife blade. Even with the putty backing it wants to give, hence when I scored the aluminium foil it actually cut right through on my previous attempt. The tail stripes are done. Turned out pretty well. Blew up the photo and overlaid it on the part and marked it out as close as possible. Hey it’s yellow and it’s stripes right? Ok Left the bomb bay unglued as well. Makes it handy to reach inside to work on turrets and windows. Fits right in place though when the time comes. Happy modeling everybody.[dinner]
