floquil primer
is it ok to wet sand flogquil primer?
Sure. I did with mine on a couple of spots.
That is the Railroad line of Floquil primer right?
correct.
Go for it then Chris. [;)]
No problem wet sanding the Floquil grey primer. Just be sure it has cured for about 48 hours. If you do it too soon you may see little balls of paint rubbing off. Speaking from experience, sadly enough.
Good advice Rick.
I always wait 48 hours before applying paint on top of another coat of paint or sanding.
