I’ve been thinking and am curious of what you guys use when using clear coats? Do you use spray cans or do you airbrush it on? I’ve been thinking of using the airbrush from now on for it lays down a nice thin coat between coats. Will enamel clear coat hurt acrylics?
I use MM Acryl flat airbrushed for any flat coats. Gloss I usually use MM Lacquer Clear Gloss from a can but I am in the process of switching to Alclad’s gloss after seeing some others work with it here. It can also be airbrushed which is a plus. I always worry about getting it too think out of a rattle can.
I am going to give the Vallejo PolyUrethane clears a try someday. I have read a lot of positive comments on the forum the last year or two.
I used Pledge and Pledge with Tamiya Flat Base a few times, but, that is not my favorite.
My favorite is Aeromaster Acrylic clears, or Polly Scale clears,I have a shipment of all three Aeromaster sheens coming to replenish my stock on Monday.
It is dead simple to use, just mix 75% clear with 25% thinner, and spray away.
A good question regarding airbrushing clearcoats: do I still have to thin Model Master clearcoats with thinner or can it be used straight out of the bottle? Something tells me I do need to thin it.
I use acrylics for my paint and I use the testor rattle cans of flat and gloss coats. I had the vallejo ones but I could never get them get a smooth coat
I’ve still got a few Polly Scale clears kicking around in case I run out of my preferred standard, which are the Alclad II clear coats. Their series of different flats are the best I’ve ever used by far.
Gloss clearcoats need to go on very wet. To do a wet coat reduce pressure and get closer to the surface. Too high a pressure or too great a distance of airbrush to surface will give a rough surface.
Not sure whose varnish, nor type you are referring too. I have used regular polyurethane varnish as a clearcoat, and I do thin it anywhere from 1:1 to about what you mentioned. The one thing I like about polyurethane varnish is that it is available in satin (semi-gloss). Most of the time I use Testors dullcoat or glosscoat. In either case, a glosscoat needs to go down very wet.
