First Diorama
Im on the last stages of putting together parts for a diorama,but how do I make desert type scene on a low budget? My diorama will be depicting a SOF unit under fire while extracting a fallen comrade. Any sugguestions? Pics would helpfulif possible.
how low a budget?
sand on a board is too flat, so it should have some variety on the board.
find a suitable base, and seal it so plaster or celluclay won’t soak in and warp the base.
plaster of paris and celluclay can be purchased in small containers choose ONE or the other. both can work, mix with water and spread on the base. it should be thick enough that it does not run off the base. as it sets you can add ridges and other hi-lights like wheel-track marks
when dry cover with white glue and add your sand
woodland scenics makes a spray on glue but you can water down the white glue so it can be used in pump bottles
