First AFV build Walker Bulldog, pics
Thought I would share to get some constructive critisism on my first AFV build.
I have been building cars and airplanes for years so I decided to try a AFV. This is the turret on a Tamiya Walker bulldog with Eduard and Ordanance PE, some scratch built and resin parts thrown in hear and there as well. Please post your opinions good or bad as well as any advise. Thanks! [:D]
It doesn’t look like the picture posted.
Please post again. We want to see it.
Go here and follow the directions.
[urlhttp://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=10017][/url]
I’ve had the same problems posting pictures too.
Go here and follow the directions. They’re in about the third post.
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=30
Don’t forget to “right click” on your picture and get the address from the “properties” section.
Finally!!! Got the pics up. Let me know what you think!!! All comments are welcome.
No criticisms coming from my end … looks like she’s coming along nicely !!!
I’m unfamiliar with Ordnance PE … how did you find their product to be?
Thanks for sharing.
Thanks Sherman… The Ordanance PE is OK. Its limited with only 1 small sheet and three pieces of resin. The Eduard set has two very nice sheets that cover just about every shortcoming of the tamiya kit. But the Ordanance PE did have a nice resin 50 cal mount. For the cost of the Oranance PE I figured I would get both and use the best of each set.
Looks good route62. Keep it up.
looks like its a nice clean build!!
Looking Good!
Keep going!
gee, that is pretty good-but then you are an experienced modeler, i hope you like the best forum of all!
Looks pretty good to me. Those PE just make it better.
More pics.
Coming along great. Keep us posted.
Very nice build. The PE and resin really makes it come alive. How did you do the oval vision blocks?
I also like your laptop…!
Gip Winecoff
Looking good, route62!
I’d be proud to have my Tiger take it out, err, meet it in combat [;)]
Looking good!
Nice job on the grab handles.
Yeah, nice all over! Keep up the good work!
Thanks for the encouragement. The oval blocks styrene, were solid molding in the kit. I drilled them out and then added the eduard PE rivet surround to give it more detail. After laying down the paint I will add glass from the inside using blister pack plastic to give it a realistic reflection of vision blocks. Thanks again
Got a little more done on the Tamiya M41 Bulldog from the last time I posted. Finished the Verlinden 50 cal MG uisng some of the PE that came with the Eduard set for the bulldog. This is the first time I have used Verlinden and I am sold!!! Nice detail on the MG and all the parts are molded seperately so you have lots of options on how you want to pose your MG.
Also added a Barrel Depot barrel in place of the kit barrel. I did cut off the kit muzzle and attached it to the metal barrel since this is not supplied with tne Barrel Depot barrel. Comments always welcome!!![:D]
