Finished SBD and TBM
1/48 Accurate Miniatures.
http://www.helloproduct.com/slideshow/
Simply breathtaking, awesome building Caleb! A couple minor issues with molding lines and a non-sooty exhaust pipe…and that SBD with the (I assume) damage to the insignia from tracer fire is really inspired![tup] That bird looks like a true Vet!
Overall, both are Outstanding! IMO
thanks. these are my first AM kits, i have built all the other big brands, and AM is by far my fav.
Great builds there that duantless is nice! [:D] To me the TBM’s instructions were complicated.
yeah, with AM instructions you def have to read instead of just looking at the illustrations.
Nice models and a good way of displaying them on your web site, too. Very entertaining.
I agree, those are some great builds on your site. My favorite is the TBM. It’s just a Monster for a single engine bird. There’s some fine detail painting inside those pics. Thanks for sharing, and we’d love to see more.
Semper Fi,
Chris
How true Chris. Shots of a TBF/TBM on a carrier deck with aircrew really point out the huge size of those birds. Same with the Helldiver.
I’ve seen pics of a TBF where the pilot looks like 1/72 scale figure driving a 1/48 scale airplane
Well done! I have the AM SBD on my bench right now. How did you find the fit between the fuse halves and the accessory panels behind the cowl? They are a bugger on mine.
Yours looks outstanding! Thanks for the inspiration to keep going on mine. [tup]
im not sure i know what you are refering to. the only fit issue i had we the accessory panel just aft of the rear gunner. i taped the two halves together and eased the rear bulkhead through the bottom opening. i worked the part around and got a good fit, from there i glued it to one side of the fuselage halve and gave it a shot of CA kicker. from there you can remove the taped halves. does this help?
Hmmm… I know what parts you mean, but they weren’t the parts that are fighting me. The two pieces that are glued together which include the bomb trapeze on the bottom, and are then glue to the front of the two fuselage halves. Mine are fairly warped, so the joint has required a lot of sanding, filing, and such. I’ll get it, just wasn’t expecting this much trouble with it!
hrrmm, i really didnt have any issues at all with those parts. maybe you can take a photo?
I will take one in the next day or so, thanks for the help! [tup]
cool, cause i have another AM SBD kit im going to start soon and maybe i can avoid your problem when i build it.
OOPS! I forgot to take that photo. I will get it done tonight and post it for you. [tup]
OK, I went and took those pics straight away! Here’s a photo of each side. The fit was the best I could muster, but I am certain that part of the problem is self-induced! One thing I became accutely aware of during the build- test fit…TEST FIT…TEST FIT!!! I didn’t test the fit of the wing to the fuse, and w/o the positive attachment managed to get it slightly askew which caused all sorts of fit issues later on. I accept full responsibility for THAT one! [D)]
Here’s my other trouble spot:
ok yeah i remember that. i just filled it with putty and let it dry for a bit then removed the rest with nail polish remover. however my mold was not as bad as yours. yours seems to be uneven, and mine just had a gap on both sides.
Wow! **Frankie…**that is an ugly fit…and I have an unopened one in the stash![BH]
But I had the same (or similar) trouble years ago on a Testor’s 1/48 TBF…a blowdryer probably would have done it…but didn’t think of it…so I fired up the oven and stood in front of it massaging the piece into the shape it needed to be. Man…this is old school!
I kept checking over my shoulder for the GF ready to ask WTF are you doing!?!
It was painful, but it worked. Just too much detail to try to sand putty at that type joint!
(Oh! I started at 350 degrees with the cowl on a piece of foil…not a good idea!…I could tell foil was getting too hot…turned it up to broiler mode and just manipulated the cowl under the hea. Like I said…it worked, but I don’t necessarily recommend it![}:)]
Nam,
Good idea! I can see it now:
“What’s for dinner honey?”
“BEARCAT!!!”
LOL, unfortunately I have already glued mine together. Didn’t realize how bad the fit was until finished. I thought it was better, but alas… On the real aircraft the gap there is quite pronounced, perhaps I will just proceed and call it a learning experience. [sigh] Sorry semibold, didn’t mean to hijack your thread.
“almost” boiling water will work too. i know people who have used it to “droop” helo props. i would boil some water and pour it onto a casserole dish and let it sit for a few seconds. try it on some scraps first!
