Pretty cool Hans, give us some info on the dio, what kits were used, scale, etc.
Very nice!
not bad friend.[tup]
Nice dio, also very good trucks.
Nut still one thing disturbed me, usually they don’t use foam(that white thing for fire extinguishing) and water together, because water washes foam away and its no use of foam.
Thanks for the thumbs up!
Kelly_Zak
most of my dio like the firefighters,playground, debris etc.is made from schratch(plaster and clay).
all trucks are kitbashed 1/64 scale Code 3 models.
the only kits i used is the ruine which is made by twobrothers(tsjechia??)along with the 1/72? scale red arrows jet(dunno what type airplane it is)
Laurts, you’re not quit right about the foam water combo.
the foam is put on not to extuingish a fire but to prevent the jetfeul to ignite.
the water is put on to cool the jet engine down preventing the feul to ignite by it’s heat.
oops forgot to add:
engine 9 in the background has some led’s built in.
see more dio pics on my epson
http://albums.photo.epson.com/j/AlbumIndex?u=4159018&a=31168565&f=
Pretty nice work. Thanks for sharing.
Regards, Rick
Great build. And from what I saw from your link you like fire engines, nice collection. Well I guess I should ask if that collection was yours?
Thanks for the show.
Nice job. Some what of a different subject than what is normally posted. Looks great. Thanks for sharing.
Great job Hans. Even got the Chiefs car placed correctly. Right in the way.
Laurts - Actually water and foam get used togetehr alot, since it is water and the foam concentrate that make the foam.
wow. impressive work.
joe
thanks guys.
Skarpotchi,
yes this is my current collection although lots of them are replaced by others.
