Fine Lines
I’ve added a page to my website on producing fine lines with an airbrush. Comments and suggestions are welcome.
Don
Don,
Thanks for the work you put into your page. Lots of great info on there that I will reference…no doubt.
It will be much easier to draw fine lines when starting with the right equipment:
(1) A small nozzle head, 0.35 mm is ok, 0.2 is better.
(2) A needle with long taper (small taper angle). 6.5 degrees ok, 5 degrees better.
(3) Then add a pre-set handle.
On second thought, we was the last time I wanted to draw a real fine line when modeling? I just can’t remember that it ever happened.
If you have superb artistic skill and experiences, the above does not apply.
