Fine Head Assembly
okay, so i have a fine head assembly for my airbrush, now, do i need a different needle, or can i swap the needle from my medium into this head?
What type (brand) of airbrush ? I have a Badger 150, and the head assembly is designed to work with the corresponding needle. (fine head/ fine needle). Driving a medium needle into a fine head (if its even possible) will damage the head assembly. Hope this helps !
Hello
I suggest you verify the recommendations of the airbrush manufacturer as there is a lot of different cases, but roughly a needle corresponds with a nozzle. If you consider that whatever needle you take, the "diamètre de fil " (litterally wire diameter that is the diameter of the needle body) is the same then the difference is only in the needle tip and its taper; then imagine what can occur if needle and nozzle are not fit. Incidentally, I tried a .50 grey needle on a .30 tan nozzle on my Aztek and the result seemed that the spray was narrower then the standard set, but don’t try to do this at home kids, because my .30 head will be very fragile now, I think
J’ai bon, là, Mike ?
Hope this humble opinion will help you
hmmm…thanks guys…sounds like i better set out to find a fine needle…they are all over the place on the web, i’m just annoyed at myself for not thinking to order at the same time i ordered the head assembly
Dont worry you can fine all three types of needlas on ebay for about 3to5 dollars.
