I picked up some kits recently that are missing parts and instructions. I got them second hand, so there’s no returning to the store or manufacturer replacement options here. Now I have tried contacting the manufacturers about purchasing the parts, but it’s either taking them a long time or I’ve got no response at all. I’ve also looked for aftermarket options but no luck there. Does anyone know of a source for possible parts and instructions?
What kits instructions do you need? What parts? Someone on here can probably help you out if they know what you need. Good luck!
Academy 1/ 48 F-111C ; need instructions, cockpit and most of the nose.
Tamiya 1/32 F-15E; need instructions and two trees, H, which is the lower fuselage half and all of tree G. Also need the decals.
Thanks
bump
Anyone?
Thas a tall order there TopDuck fot the F-15 parts. I think anything other than dealing with Tamiya directly will be futile. Good luck If tyou can get the parts she’ll make for one nice build.
Soulcrusher
Your best bet with kits that are missing that much is to just use them as a parts source for other projects. Weapons, wheels and many parts can be used.
Darwin, O.F. [alien]
