[?] Does anyone know where I might find a FedEx delivery truck model ?
You might try contacting someone with fedex. I know a local concrete co. a few years ago had ones of thier trucks for promo uses.
i seen an old chevy panel truck on ebay that was sportin the fedex logo. check it out it might still be there.
You could try scratchbuilding one. I built a GMC stepvan from sheet plastic card some time ago. It’s not that hard, most of it is flat panels. for the curves use plastic tube, butt the sheet up to it, cover in filler, then rub down. For the dimensions, find a real one, measure in inches & build the model at 1mm to the inch, instant 1/24th scale (ish)
Pete
I found a 1940 Ford panel delivery truck. I think the FedEx Airbus 300 1/144 scale might work with model. I think it would make an interesting project. Any suggestions would helpful. Thanks for your ideas.
