F9F Nose Weight
How much weight do i need to put in the nose of the monogram F9F Panther 1/48th scale?
rhino II
Lots! I didn’t weigh it out, but I buy the pencil style fishing weights and stuck 3" worth cut into 1" lengths into the nose. Flattened it out then bent it to fit the curve of the fuselage and CA it in place then painted over top. You can’t see it through the clear glass panel on the bottom.
thanks for the info.
rhino II
