F-15E airbrake
I’m building the Revell 1/48 F-15E and was wondering about the air brake position for this model. On the box the air brake is shown up but I don’t think this is the position that a parked F-15E would have it in correct? I was painting parts white the other day and started to paint the inside of the air brake and noticed pin removal mold marks that needed to be filled first, but now after looking at a few pictures I don’t think I will even have the air brake up so painting it is not needed.
Is this how you people have built your F-15E?
Thanks
The F-15s i have built, I have The brake down. Of all the pictures ive seen, it was only up on landing.
Thanks Flanker.
That’s what I thought also. Isn’t it funny how they picture these aircraft on the box they come in? [:D]
The speedbrake on the F-15 is normally closed on the ground unless some maintenance is being conducted, and if you model it up it has a red safety device installed on the piston to keep it from closing. On a few aircraft there are some intresting things painted underneath the speedbrake, usually not for public consumption.
Thanks for the info Charles. Now you have my curiosity as to what “words of wisdom” these pilots and WSO’s have painted under that airbrake. [:D]
MikeV, which F-15E markings are you doing and are you doing a particular aircraft? I’m working on a 1/72 F-15E using Two Bobs decals for Seymore Johnson and modifying them to match the plane I took refuge from the sun under at a recent airshow. Funny, the Two Bobs decals have yellow band on vertical tails while the two at the airshow had blue there.
Plum1030
There are four different squadrons at Seymore Johnson and each has a different tail strip color so go ahead and paint yours the color you seen at the air show and you’ll still be right.
Good to know. I just need to make sure the numbers are right as well. Thanks Charles.
The air brakes are also used for combat maneuvering. So, it is possible to see the air brake deployed while in flight, but not for landing.
I, also, always build mine with the brake in the closed position. Makes it easier to paint!!
On the F-15Cs at Langley, they used to deploy the brake during landing. I also helped do some launch assists one TDY and they would deploy the brake during the run up to make sure it worked.
Wroper
I haven’t really decided which decals I want to use yet ,but I do like the “Tiger Meet” ones on the 366th FW - 391st FS out of Mountain Home AFB in Idaho.
Like this guy did on this 1/32 Tamiya F-15E here: http://www.naritafamily.com/howto/photo_frame.htm.
I would imagine the ones that came with the kit are the usual Revell junk right, or has Revell finally put some good ones in with the kit?
Hey wroper11 A bunch of people here in the newsroom want the 4-1-1 on your sig tag. Where, who, when etc. Don’t think I will get to cover the sugar bowl. Besides, I really want to go to the Orange bowl next year. Got friends in Little Havana I would love to drop in on. Not to mention, we need to pay back Miami a little [;)]
Speed brakes are also up during com. out launchs to indicate a problem that needs attention, or a fly-by to let his/her crew chief know something will need attention when he/she gets back to his/her spot.
Cgarman,
I don’t really understand what info you want. LOL
I dont know all the computer jargon. Sorry but I am a little slow don’t abbreviate.[:D][:D]
Wroper
Where did the photo come from… Some Sooners here in the sooner state would like to know.
My sister sent it to me. I don’t know where she got it from, however she works I.T. at OU and gets cool OU stuff in the e-mail all the time.
wroper
