F-104G gun mount pics?
Hey all - Wondering if anyone has a better pic than this one showing the gun on an F-104G. Seems to me that the gun in this pic is missing, and if the gun barrel actually protrudes from this opening I would like to add it to my model. In this pic you can see what looks like a rubber seal from which the barrel should protrude.
Any help is greatly appreciated.
stinger
The F-104 carried the Mark 61 Vulcan 20mm cannon. Gatling gun. No barrel
protruded…
Ray
Thanks Ray - So is the gat mounted inside this housing, and the rounds pass through the opening shown in my pic?
stinger
As the barrels turn, the barrel that fires is in direct line with the opening. It has a safety switch that prevents them from firing out of sequence. Sometimes there is what is called a short shot or cooked off shot, where one barrel will fire out of sequence, which causes damage to the aircraft.
No doubt!!
Thanks Berny - I know a bit about how Gat’s work. I was just surprised that the round would have to pass through what appears to be a not-so-clear opening. Looks to me like the round would scrape the rubber seal, but I guess at those high velocities it wouldn’t matter. (?)
stinger
