excited too try these solutions but still unsure of my results
I would like a professional look on my kits and have read quite a bit of the pros and cons too using setting solutions…i guess its all in surface prep and patience…still gonna give these a try…
You mean for decals? I find them a must on most decals. Just use a little at a time, expect the decal to wrinkle a little bit, then leave them alone to dry.
Setting solutions are pretty benign. There is little reason not to try them. Decal solvents are something else. They can be tricky- some decals dissolve completely in them. I always use setting solutions, but only work with solvents when normal setting solutions- with repeated applications- just cannot get decals to nestle down. Applying decals to compound curves is one place where solvents may be called for.
