Equipment help
Ive got my M4 sherman almost done but i need to make equipment like sleeping bags and blankets. HOw would i go on making this stuff?
I need to scratchbuild it because my diorama has taken up all my moneY!
I don’t do dioramas but I used to work with a guy who did. For things like that he put Elmers white glue on tissue paper, got it to the shape he wanted, let the glue dry, then painted it.
As Scott said ,dilute some white glue with water ,take some ordinary bathroom tissue and lightly brush the glue over the tissue.After it dries and stiffens up you can spray it any color.After that dries you can roll it up and it makes great tarps.You can also use it to go over vehicles and things when it is still damp and it will conform (like the canvas top on a truck).Good luck Lonnie
thx u guys my sherman needed a tarp to cover damage lol
Ordinary bathroom tissue will fall apart while wet. A better paper is facial tissue such a Klenex. You can " play with it " while it’s wet to shape it and arrange it as needed—even roll it into bedrolls and stored tarps.
kinsaka;
As posted above, ordinary toilet roll will disintegrate when wet (by design) What I have had really great results with is tissue paper that comes with a new dress shirt or from a gift shop for wrapping china. It is very sturdy and comes in a large enough piece to make nearly any “fabric” object.
As above dilute white glue in a 50/50 mix with water first. Dunk your object in the mix. Form the object and let it dry in place on the model. Do not try and form a dry object to a model, the results are very poor. If you’re doing a tarp over items remember to give the tarp some “gravity” press it down to contact the tops of the items it is covering. As well an insecure tarp will blow off a moving vehicle. “Secure” your tarp with a fine string. I use the cords from tea bags. I brew up a pot drop the bags in. When the steep is done I pull the bags out. Pour some of the fresh tea in a shallow dish and “dye” cords from the teabags. Makes realistic looking rope and is very close to scale for 1/35. I then place the bags flat to drain and dry. Tea leaves work great for diorama bushes and trees.
Now once I have placed,secured,gravitied my tarp. There is one more step I use to mask the telltale nature of tissue paper when painted. I take my trusty bottle of “SPRUE GOO” (diced sprue in liquid cement that liquifies over time to a thick paste) I take it down from the shelf and layer it on the tarp to cover the texture of the tissue and give me a smooth surface to work with in the paint phase.
When done it hardens and allows the items to appear to be all one piece (some almost looked like resin castings) Then it is just a matter of painting and shadowing etc, etc,.
I hope this helps. Any questions please feel free to email.
Cheers;
Gregory
