Envirotex Questions
I’m about to take the Envirotex plunge to make clear Botanical windows on my 1701A Secondary hull. I’ve used Loctite Gel Epoxy but it wasn’t very clear. I have heard that Envirotex will dry clear.
  1. When pouring Envirotex into the windows, are you doing it from the inside of the model?
2.Will the “blue” masking tape serve as a good background to hold the Envirotex in the window area without sticking to the tape?
  1. What, if any, problems should I expect to encounter while doing this?
I greatly appreciate the help and/or suggestions
Thanks in advance
Jack
