engines, airline hoses.
does anybody know what size wiring should be used for running fuel line sprkplg, and airlinehoses on pu,s and big tks.
thanxs paul
I don’t know the actual measurements but Radio Shack carries what’s called wire wrapping wire which is, I believe, 30 gauge that works well for sparkplug wiring. Anything in that range should work well for you. You can also use fine solder for fuel lines, etc. Hope that helps you out.
Ray
Also check Caft stores (like Micheal’s etc). They have different sizes of fine wire for crafters… some are perfect for auto wiring, hoses etc…
Try www.detailmaster.com. They have everything you will need.
Lee
