Enamel Wire??
Ok what is it? The instructions show to tie the pe exhaust cover with it. Here’s what I am talking about :
It bassically is coper wire with an enamel coating, time to visit the old Arts Supply store.
Often used to make custom jewellery, and more uses in the modelling hobby.
I get mine from the LHS, check the car AM section.
Thanks MMF. Do you think using a single strand out of something like speaker wire could work as well though. I’m not really near any craft stores and don’t know when I would be getting back by one.
I am pretty sure it would work or fine floral wire should also to the trick.
Most of the enamel wire I have seen has a black coating, and maybe that is why they recommend it.
Been a while since I did the Kit.
It should be in the kit Chris … a very fine copper coloured wire.
Ahhh, well what do you know there it is [:I]. Seems like my brain got to thinking before it really got to thinking[B)]. Sometimes it helps to look in the other box instead of outside the box . Thanks Robert.
