My next project will consist of working head and tailights. Have any of you ever added electronics to any of your builds? The problem I seem to be facing is the size of the power source. A nine volt or even AA batteries are just to big. The kit i’m doing is the Boyd Coddington Aluma Coupe. Whats nice about this car is that there is no frame. The body is totally enclosed. Its a perfect candidate for hiding all sorts of electronic components. But the power source has to be small enough to hide, yet I need to get to it should I need to change out the battery! Ive tried RAM electronics. The power sources are too big. Iv’e tried Micromark’s small electronic section. Still to big of power supply. Also LEDs are going to be used since they draw minimal power. BUT WHAT CAN I USE FOR THE SOURCE? The components have to be totally contained withinside the car. Pleas help me![banghead]
If you are using LEDs you may be able to use some of the smaller camera batteries. Can’t remember the sizes they use but it’s something like N. They are still 1.5 v. You might could consider mounting the car on a base and having the power supply running through it to the source. I saw a display case that had small flood lights in it and a lighted gas pump that was this way. That would not work if you are wanting it to be stand alone though. Still with LEDs the battery should last for a very long time. I have a head lamp that with 4 LEDs in it says it will run for 750 hours off of 2 AAA batteries. If you only turn the lights on when you are showing it off then you may never have to change the batteries.
I’ve added electronics and lights to a number of my models, but most of them have been space and/or sci-fi models.
Since you’re doing a car, check out RAM RC: www.ramrcandramtrack.com
They offer a pre-wired set of LED-powered head- and tail lights. All you have to do is install the set in the model and add a battery. I have one of their sets in my “to-do” pile, and it’s very well made. It has a battery pack for 2 AA batteries, but I’m sure it could be adapted for smaller batteries without too much trouble.
Matt Usher
Hi Mathew, and thanks for the advise, my friend. Actually I think iv’e found something that will work. I found a 12 volt battery that’s exactally half the size of a AAA battery! I think this will work for me. That should power the headlights up front and the tail. The tail light bar is whats really going to set this model off. I’m doing the “knight rider” effect. The LED that moves back and fourth. I found the wiring diagram on the internet. I believe I can get the board small enough to fit where I need it. This project will take every bit of this year to finish. I plan on having opening doors as well. I should be able to pull this off and show no indication of wires, components, etc… I do have my work cut out for me though!
Sounds like a great looking build once it’s done.Keep us posted on your progress.
