As someone who has never tried either of these, or any die cut masks, which of these are the easiest to use for a first timer. Got the Eduard for the Betty I’m building, but if the Montex is easier don’t mind going that route.
Opinions from those that have used both, or either welcomed.
I’ve used Both. A plus for Montex is they include masks for the inside frames as well. But Eduard also includes other masks for things such as landing lights and wheels in their sets. The Montex sets are vinyl and are a bit trickier to position. But they do stand up better when you have to fill and sand near the canopy once its on the model, as I always mask the clear parts before I attach them. In general I usually find myself going the Eduard route. I suppose they are more easily available too, as now I can only get Montex stuff on Ebay.
I’ve used EZ masks, vinyl and seemed to work really well. Worth giving a try I’d say. Be sure to read the tips sections if you choose to try them. “Betty”? 1/48? See #26 here:
Thanks guys, started with the Eduard since I have it on hand Stuff is as big a pain and patience trying exercise as my ex… But hopefully will be worth the effort when all is done. Be glad when I get to the RF and the Mustang.[*-)]
Can’t see what the deal is. The Eduard masks are as simple as it gets. Just need a good light and a sharp knife and fine tweezers. They can be positioned multiple times.
Yep, easy and stick well when burnished down. Just that homeboy has big fingers (more like 12 thumbs when they get to intricate things) and hands and was clumsy as a kid and never outgrew it…lol
My first Eduard masking job wasn’t all that long ago, so I can empathize with you.
It gets easier, and after another kit or two, you’ll be an old pro. In addition to tips already mentioned, I find magnification a huge help. I use an Optivisor, myself.
If you remove them carefully after painting, you can even use them again if any touch up masking is required.
