I bought the Eduard 1/48 BF110 Royal Class kit and just started it. First thing I would recommend is to break the kit out into Kit A and Kit B. The sprues are huge and confusing for one kit let alone sorting through two kits.
Great work do far. Those Royal Class kits are really nice. Good to see someone building one. Did you get any unboxing pics?
Looking good. I built the C version a few years ago. Nice kit, Be forewarned though, its tricky fitting the engines to the fuselage…alot of sanding and re-sribing. If you intend to close the gun bay like I did, then the fit up front will be tricky. The top cover is too short so you have to trim the lower part to make them even, otherwise, there will be a gap on top. Gun exposed, no problem I would imagine. Other than that, it was fairly straighforward if I remember correctly.
Engines to the wings I mean’t…whoops
