Here’s a link to my latest project, Eduard’s P-39L Airacobra Dual Combo. This was my first fully airbrushed model and though mistakes were made, i’m satisified with it and I learned from them so hopefully the next project will be even better.
Interesting. Wonder if it’s a flaw common to the kit… I’m having the same issue on the P-400 on the bench right now. It has me at a stopping point as I work on a solution.
DiscoStu, if you’re building the Hasegawa Bell P-400, when you go to attach the canopy you will need to squeeze the fuselage a little until the edge if the canopy and the fuselage edge match. Then you can glue the canopy to the fuselage. I had to hold the two together with a couple of Harbor Freight plastic clamps until the glue had set overnight. I used Tamiya Extra Thin to attach the canopy.
