I just found out that If you load the Future into an empty lens cleaner bottle and spray it like the lens cleany stuff, it works like an airbrush except the noise pollution of the compressor or the extreme cold of the compressed aircan is gone.
It may work, I’ve never tried it. But the pump action can’t give you the same level of atomization spray that an AB can. You’ll end up with a much heavier spray & run a higher risk of runs or unwanted build up.
I’ve never tried it either, but had the same idea a few years back. Diecussion at another site, pretty much said, don’t do it. As rjk said, you won’t get the same degree of atomization, built up/uneven coats can be problematic and tiny air bubbles is some thing you don’t want in a clear finish.
