E-Z Mask, Polly Scale Flat, and Future
I have a lot of questions. Before this is over you’ll be thinking will this guy ever shut up! But, here it goes.
  1. What is E-Z mask and how do you use it. Is it good or bad.
  2. Polly Scale Flat coat. Is this something you can use for sealing a model. If not, what is a good product for sealing the decals and then the model once done weathering.
3.Is future good for sealing decals and if so, do you apply it using a brush or do you spray it on.
Thanks in advance,
David
David,
Here is a good read that gzt directed me to in regards to future, I believe it has some info on decals there;
http://www.swannysmodels.com/TheCompleteFuture.html
Hope this helps!
