Dusty Panel lines
when you scribe the panel lines and smooth them down, dust collects in the recession. how do you remove this dust?
Thanks
OWL
Just hold the model under running water and give it a couple swipes with an old toothbrush.
I’ve seen some people even out the lines with a light coat of a mild liquid cement like the pink label Testors as well.
A quck puff of breath does the trick too.
I use a sharpened toothpick to clean out the line followed by an old tooth brush.
Your airbrush or one of those cans of compressed air for cleaning electronics. Wash and brush as mentioned. You can also run a bead of liquid solvent down the line to set the dust into the groove.
Liquid solvent?
Yeah, the same solvent you would use to assemble the kit. I prefer Weld-On #3
